• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Smart Team and AutoCAD P&ID 2007
    282 Views, 1 Replies
    01-15-2008 12:47 PM
    Can AutoCAD P&ID 2007 be integrated with Smart Team allowing users to work within design environment and perform typical PDM functions such as advance searches, enabling a quick preview of documents without opening the application that created them, easy "Where Used" retrieval, revision control, and product life cycle operations (check in, check out release and obsolete)? Does this also apply to AutoCAD P&ID 2008?
    Thank you
    Please use plain text.
    Valued Contributor
    Re: Smart Team and AutoCAD P&ID 2007
    01-18-2008 06:34 AM in reply to: EZTCADSYS
    At this time it cannot be integrated with any PDM provider unless the PDM software can track and use the projectstyle file and the project xml and associated files as well.
    We are using PDMWorks with our 2007 P&ID installation. In order to archive and control versions we are basically copying the files into the vault only.
    There is more to the overall process that we have come up with but its a little tedious. I can elaborate further it you like?
    Mike
