• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Roxana-Elena
    Rotation of Instrument Bubbles not Possible
    604 Views, 5 Replies
    10-25-2011 02:03 AM
    Is possible to get a fast answer for my following problem:
    I create a new instrument bubble and bring it to Project Setup as any other custom symbol. I set the attachment points and the annotation format. I set the "Rotation on insert" to "Yes". I bring it to tool palet. I insert the bubble, gives me the posibility to rotate but when I release it comes to horizontal position.
    I create an empty bubble (without any annotation) , follow same procedure as previous. I insert it and after releasing it everything is according to needed rotation angle.
    I have attached the editor block view for the instrument what I use in my project. I suppose the problem cause is the too long annotation format. But this I can't change.
    Is there anyone able to help me?
    Thank you in advance
    Roxana
    Please use plain text.
    Valued Contributor
    Heckmeck
    Re: Rotation of Instrument Bubbles not Possible
    11-16-2011 06:42 AM in reply to: Roxana-Elena
    I have experienced the exact same problem.
    Would be great if someone can test it or give a hint.
    Valued Contributor
    gschimmi
    09-12-2012 11:54 PM in reply to: Heckmeck
    Hello
    is there some new knowledge for that problem?
    I have to rotate the bubbles in a project :-(
    thx
    Guido
    Valued Contributor
    Heckmeck
    09-25-2012 06:25 AM in reply to: gschimmi
    The way I did it, was to create a already rotated symbol and add it as a second symbol for your instrument.
    Then you can place your instrument, do a right-click, and choose the rotated symbol.
    Valued Contributor
    gschimmi
    09-25-2012 06:44 AM in reply to: Heckmeck
    OK, I'll go the same way..
    04-09-2013 09:38 AM in reply to: Heckmeck
    I see this a 1,5 year old post...
    Has annyone found a solution for this problem yet?
    why is it always horizontal?
    there should be an option to rotate it i guess??
    Somethimes when an instrument is added, you just do not have enough space for it.. espacialy when you have "wide" instrumentsymbols with a  6 digits loopnumber...
