• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Mentor
    JohnHolder
    Resetting Valve numbering in P&ID
    322 Views, 5 Replies
    01-01-2012 11:06 AM
    I did it once, now I forgot how to do this....
    as the subject, I have deleted a few valves and then added them back into the drawing, but there is a large gap in the automatic numbering.  I reset the numbering once, but I cannot remember how to do it again.
    Anyone point me the right way?
    and Merry New Year everyone!
    John.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    Valued Mentor
    ybogdanov
    Re: Resetting Valve numbering in P&ID
    01-01-2012 03:17 PM in reply to: JohnHolder
    Configuration of TAG in the Project Setup, in the propertie of the tag enter to the format configuration (forth icon, first is to select properties of objects, second properties of drawing, third properties of project, and forth is format of selected propertie). And now go to part of autogenerate and reset the number.
     Another way to change this option in only one drawing is press right button to one P&ID drawing and select "Drawing Autogen Propertie...)
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Valued Mentor
    JohnHolder
    01-03-2012 12:11 PM in reply to: ybogdanov
    i must be looking in the wrong spot still.  I cannot access any properties for the TAG field.
    also I have tried changing the "drawing autogen Properties"  then "Audit project" and it does nothing.
     I hate this,  I found it once, and said OH there it is... that makes sense.... but for the life of me I cannot find it again now.
    Master Yoda.
    Active Member
    K.Skauge
    01-10-2012 07:04 AM in reply to: JohnHolder
    How about if you:
    1. Open the project manager
    2. Mark the drawing and right click to open a menu.
    3. Choose "Drawing autogen properties"
    Does that work?
    Valued Mentor
    JohnHolder
    01-10-2012 09:57 AM in reply to: K.Skauge
    Already tried that as posted
    Master Yoda.
    Product Support
    jason.drew
    01-10-2012 10:54 AM in reply to: JohnHolder
    John,
    There is a course handout from AU 2009 that might help:
    http://au.autodesk.com/?nd=class&session_id=5168
    It has a very in-depth guide for configuring the autogeneration properties in Project Setup.
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
