• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Member
    Rename Class Name in project manager
    636 Views, 3 Replies
    11-20-2012 06:13 AM
    I am required to use a french version of autocad P&ID 2013 and need to rename the class name descriptions in the project manager.
    I am able to do this manually for each item , but it is taking a long time.
    Is there a file that I can edit to change these items instead of having to go to each class.
    thanks
    Please use plain text.
    Active Contributor
    rchiasson
    Re: Rename Class Name in project manager
    12-05-2012 09:24 AM in reply to: graham1414
    That I know of at the moment, there is no easy way for doing this besides individually. Similar if you want your equipment to come in a different color.
    Keough
    12-05-2012 01:06 PM in reply to: rchiasson
    Unfortunately I cannot help with the renaming.
    To change the color of all the equipment at once, you can try going to the projSymbolStyle drawing and changing the equipment layer color via the layer menu, this will affect anything on that particular layer in your project.
    Active Contributor
    02-20-2013 06:03 AM in reply to: Keough
    I have the same problem, is there a solution in 2013 version ?.  Which is the easiest way to change the class name and the Graphic Style in a line thats already drawn ?
