• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Re: Publish always fails
    09-11-2012 07:11 AM in reply to: aeiken
    Hi Dan,
    I started looking at the system variables for AutCAD P&ID 2013 for publishing. I tried setting PUBLISHCOLLATE to 0 instead of the initial value of 1. That seems to have done the trick. I've been able to publish using the same old page setups that I've been trying since AutoCAD P&ID 2013 was installed. All sheets publish without errors. Publish seems to fail after the first drawing when PUBLISHCOLLATE is set to 1.
    Ken
    Please use plain text.
    Product Support
    09-11-2012 07:26 AM in reply to: aeiken
    Hi Ken,
    Good find.
    I'll test this and log it with our developers.
    Dan
    Dan Scales
    Product Support Specialist
    Product Support
    09-11-2012 08:43 AM in reply to: DanScales
    Hi Ken,
    I can't get the publish command to fail on my machine here.
    I tested with PUBLISHCOLLATE and BACKGROUNDPLOT set to various configurations and I always get all drawings published.
    Anyway, I am glad your issue with plotting was fixed with the PUBLISHCOLLATE variable.
    Dan
    Dan Scales
    09-12-2012 04:05 AM in reply to: aeiken
    Hi Dan, BACKGROUNDPLOT was already set to 0. Ken Miller Instrumentation and Controls AEI | AFFILIATED ENGINEERS, INC. 5802 Research Park Boulevard | Madison, WI 53719 P: 608.441.6665 | F: 608.238.2614 kmiller@aeieng.com | www.aeieng.com
