AutoCAD P&ID
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Publish always fails
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Publish always fails. Is this a known problem?
Re: Publish always fails
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you provide a little more detail on what happens when you use the PUBLISH command along with details of your workflow?
Dan
Dan Scales
Product Support Specialist
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you set all the page setups correctly in the drawings you are trying to publish?
The screen shot doesn't seem to be uploaded, could you attach it again?
Dan
Dan Scales
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Dan,
Yes, all of the page setups are correct. I have attached the paths in a pdf.
Ken
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Ken,
Please upload a screen capture of the "Plot and Publish Details" dialog so I can see what errors are indicated there.
Dan
Dan Scales
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Dan,
The attached plot & publish details pdf shows two plots. The one that was successful I used publish and just loaded one drawing. The other was unsuccessful. I had several drawings loaded, but it was using the same page setup and going to the same plot device as the one that was successful. For some resaon when you load more than one drawing into publisher it can't find the plot device even though I select the same page setup.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Dan,
Any news on this issue? I have a project with well over 160 drawings and growing every day. It needs to be printed atleast once a week every week. It is very time consuming to print these out one-by-one every week.
Ken
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you try setting the BACKGROUNDPLOT variable to 0 and re-test?
Dan
Dan Scales
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Dan,
I'm not sure whether you received my reply, but the BACKGROUNDPLOT was already set to 0.
