• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    Problems when open Project Properties
    432 Views, 3 Replies
    04-03-2012 04:51 PM
    I have a problem when open Propect Properties (Project Setup) in AutoCAD P&ID 2012 with any project. I use the windows 7 64 bits. See messages in files attachment.
    Alexandre
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Problems when open Project Properties
    04-03-2012 07:30 PM in reply to: alexandre.dias.tavares
    Have you also applied the hotfixes and service packs?
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    New Member
    04-04-2012 05:04 AM in reply to: alexandre.dias.tavares
    Yes, I installed the updates for 64 bits below and did not work:
    AutoCAD P&ID 2012 Service Pack 1
    AutoCAD 2012 Block Editor Save Corruption Hot Fix
    I can not configure my projects, it only appears when I click the button Setup Project. My installation is 64 bits with windows 7 Home Premium.
    Alexandre
    New Member
    06-20-2012 06:33 AM in reply to: alexandre.dias.tavares
    I have same problems. I can't view and edit project properties.I use Win7 Professional 64 bit / AutoCad PnID 2012 Student Version
    In addition, when I want to use tool palette for  ISA or PIP I can't any equipment, valve, etc...
