• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Problems changing file name
    138 Views, 1 Replies
    01-29-2008 10:26 AM
    I initially started my drawings with a B in the Drawing number. EX. 01-B-001. Then i was told to exchange the B for a D. I use the drawing number as the file name. When i changed the file name to match the drawing number, things went nuts. When i open the drawing none of the tags i have for the equipment and instruments show up. Any help would be greatly appreciated.
    Eric
    Please use plain text.
    *Jorge Lopez
    Re: Problems changing file name
    02-01-2008 10:04 AM in reply to: hinde
    Did you rename the drawing using the file manager? You can open up the
    original drawings using the Project Manager and use Save As. Then
    right-click the drawing node and select the "Update Drawing..." option. A
    file dialog will be presented where you can select the created via Save As.
    The alternative is to remove the drawing from the project, rename using file
    exporer, and then add the drawing (with new name) back.
    Does renaming the drawing back to original name first fix the nutty things
    that happened when you opened it?
    Jorge
    "Hinde" wrote in message news:5833238@discussion.autodesk.com...
    appreciated.
    Eric
