• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    owen.bannon
    Problem Adding New Instrument Linetype
    284 Views, 3 Replies
    04-05-2012 04:02 AM
    I am trying to create additional instrument linetypes in AutoCAD P&ID 2012 and I have run into a problem. I cannot get the new linetypes to display correctly on the tool pallette. They all appear as a continuous line. If I hover the cursor over the symbol I can tell which line is which. How do I change the symbol on the pallette?
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Problem Adding New Instrument Linetype
    04-08-2012 05:51 PM in reply to: owen.bannon
    You could able to edit a symbol under project setup. If its something different, please send me a screenshot of your problem.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Distinguished Contributor
    Rave.Tam
    04-08-2012 09:43 PM in reply to: owen.bannon
    You have to do it manually. First, get a snapshot of the linetype, either pngout or any other method. Then edit the "atc" file and include the image into the file.
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    New Member
    owen.bannon
    04-11-2012 07:28 AM in reply to: Rave.Tam
    Thanks for your help Rave.
