AutoCAD P&ID
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
PIDTAG dialog box
- Highlight
- Email to a Friend
PIDTAG dialog box does not display with some custom symbols that have been created. I have tried typing PIDTAG and get the following message: Invalid selection: tag can not be assigned to this entity.
Re: PIDTAG dialog box
- Highlight
- Email to a Friend
Check to make sure you have set the symbol to a tagged item. By default it is always 'Not a tagged component'.
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
You go to your ProjectSetup (right mouse click on projectname in the Projectmanager and use Properties or Home Ribbon ProjectManager and select option ProjectSetup)
Go to your Engineering Items under the P&ID DWG Settings -> P&ID Class Definitions.
Here you see the main classes Equipment, Inline Assets, Instrumentation, Lines and Nozzles.
In these classes the sub classes and the symbol classes are found.
I assume you know this, there you have created custom symbols.
At the symbol level (you have no plus sign before the class name) you find at the right side of the symbol picture
the option Edit Symbol.
With this option you set layers, insertion scale, rotation but also if the symbol is Tagged or not.
This is the option Tagging prompt. if this one is set to Not a tagged component you will never be able to give the symbol a TAG number. The other options give you the possibility to give the symbol at a given time a TAG number.
!! this is a symbol setting, if you have more than one symbols in one class you will have to do this for all of them.
- Highlight
- Email to a Friend
I did changed the settings from 'Not a Tagged Component' to 'Prompt for Tag during Component Creation' but this does not seem to make any difference. I have been able to add the tag names from the 'Edit Annotation' dialog box but not from the 'Assign Tag' dialog box. Also if I go into a drawing with any of the items that I have created that have been turned into P&ID Object Blocks their Tag name changes from (IE) EQ-HRS1-0000-0001 to EQ-? and I have to go to the Edit Annotation dialog box to revise. Please see attachment. I do thank you for your help with some of the problem the problem seems to be more than just a setting.
