• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    ugurbalbay
    PE PIPE CATALOGUE
    238 Views, 2 Replies
    02-18-2012 04:00 AM
    Dear Mates,
    We need to use PE100 pipes in our project. Unfortunately, the PE100 pipes are not existing in the pipe specification on the library. Only steel pipes (SS,CS) exist in the library. So how we can recognise PE100 PN16 pipe and fittings.
    Please attention: We work in DIN workscape.
    Yours faithfully...
    Please use plain text.
    Valued Mentor
    JohnHolder
    Re: PE PIPE CATALOGUE
    02-18-2012 08:07 PM in reply to: ugurbalbay
    You will may have to do what I just finished doing for Sch 40 and PVC-U...  build the spec yourself.  my next mini project is making a HDPE spec aswell.  it takes a bit of time, but it's doable.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Employee
    TomislavGolubovic
    02-19-2012 02:06 AM in reply to: JohnHolder
    Is this for P&ID, or do you mean Plant3D?
    If its for P&ID, the spec list can be modified, its just an entry in the Selection List of the Spec pulldown. You don't have to make files/catalogs/specs, they are just a list.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
