• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    gschimmi
    Accepted Solution
    Object enabler for PID2013
    447 Views, 4 Replies
    01-10-2013 12:51 AM
    Hello
    Is there an object enabler for PID2013 so that I can edit PIDs with AutoCad?
    Or is there any other way to do this?
    G
    Please use plain text.
    *Expert Elite*
    Rave.Tam
    Re: Object enabler for PID2013
    01-10-2013 01:36 AM in reply to: gschimmi
    If you can edit P&ID with object enabler, who will buy the software? Object enabler is used to view custom data inside custom object. Unfortunately, there's no object enabler available. However, if all you want is to edit the drawing, export it to AutoCAD first.
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    Valued Contributor
    gschimmi
    01-10-2013 01:58 AM in reply to: Rave.Tam
    Hi
    an export via dwg or dxf to AutoCad does not help. You can't pick any symbol and so you can't move or copy symbols.
    *Expert Elite*
    Rave.Tam
    01-10-2013 02:31 AM in reply to: gschimmi
    you must use the P&ID exporttoautocad command. There's a similar command for AutoCAD but that doesn't work. However, you can only export one at a time.
    Valued Contributor
    gschimmi
    01-10-2013 02:52 AM in reply to: Rave.Tam
    This is what I've searched for
