• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    Not Aquiring Pipeline Segments
    426 Views, 3 Replies
    09-13-2011 06:00 PM
    I have the following setup for aquiring the pipeline segment that an instrument is connected too.
    All pipeline segments have a field called "PipelinePnPID"
    Using a VB Net script I populate this field on each pipeline segment with its own PnPID No.
    Each Instrument has an acquired field called "PipelinePnPID" which aquires the pipeline segment field "PipelinePnPID".
    The problem I have is that the aquired field does not always aquire the Pipeline Segment field "PipelinePnPID".
    I can reactivate it using the data manager and selecting "Manual Mode" and then back to "Acquire Mode".
    Is there a way of refreshing all aquired fields, or a VB net routine I can run through a sheet?
    Note this same problem ocurrs with the built in "Size" and "Spec" fields too.
    Thank you for any help
    Please use plain text.
    Product Support
    jason.drew
    Re: Not Aquiring Pipeline Segments
    10-07-2011 12:24 PM in reply to: twhitton
    Just curious, if you manually type in the "PipelinePnPID" value on a pipe run and then select an attached instrument does the acquisition data show up?
    If so then I would say the population of the data via the VB script is causing something to be bypassed as far as a refresh on the acquision rule.
    If you're familar with ObjectARX and .NET programming I would recommend checking into the AutoCAD Plant 3D & P&ID SDK documentation.
    AutoCAD P&ID and AutoCAD Plant 3D SDK
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=15460551
    Once you're installed the SDK there is a P&ID ObjectARX Class Reference available in the help file
    SDK Install Path\PlantSDK 2012\docs\plantsdk_ref.chm
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Active Member
    10-09-2011 12:29 PM in reply to: jason.drew
    Thanks for your reply Jason.
    Yes typing the value in the "PipelinePnPID" does get aquired onto the Instrument.
    I did finally use the ObjectARX and .NET programming to refresh the aquisitions.
    MyProjectManager.RefreshAcquisitionValue(RowID,"PipelinePnPID")
    so just doing:
    DataLinksManager.SetProperties(RowID, sKeys, sVals)
    Doesn't follow through updating the aquisition rules in the API.
    It would be very useful to be able to aquire the PnPID field directly throught the Acad P&ID interface.
    Also it would be handy to have a refresh all aquisition rules directly throught the Acad P&ID interface too. (Audit doesn't do it)
    Product Support
    jason.drew
    11-02-2011 03:42 PM in reply to: twhitton
    I appreciate your feedback on this issue. I will log this with the development team.
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
