• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Accepted Solution
    Moving equipment definition between two classes
    412 Views, 1 Replies
    09-16-2012 11:52 PM
    We have several people working on on the same P&ID project.  One has defined some vessel-like equipment in one class (Tanks) and another has defined a new class (Vessels) and then defined similar equipment inside that class.
    For consistency, we'd like to move all the equipment definitions that are vessels into the new class.
    Is there an easy way to do this, or do we have to go through and recreate each definition in the new class then purge the old definitions from the other class?  If we do that, what happens to drawings in the project that have used one of these pieces of equipment?
    Please use plain text.
    Product Support
    Venkatesan.A
    Re: Moving equipment definition between two classes
    09-19-2012 08:22 PM in reply to: michael.lucas
    I had a discussion regarding your query with our database specialist
    and was informed that, unfortunately there is no such easy way to accomplish what you are looking for.
    You will have to redefine your equipment under a new vessel class.Old drawings that have equipment in the Tank class will continue to be Tanks and if you want to change them then you will have to recreate them as vessels (remove from drawings and add vessel instead).
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
