AutoCAD P&ID
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Modifying an Autocad P&ID drawing using Mechanical P&ID
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
345 Views, 4 Replies
04-18-2012 04:19 PM
I have created a P&ID using Autocad P&ID and save is as 2007 LT. When I open it with Mechanical P&ID I cannot delete lines. Is there a way to solve this problem? Thanks.
Re: Modifying an Autocad P&ID drawing using Mechanical P&ID
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-19-2012 06:00 AM in reply to:
rrui00
I am not aware of Mechanical P&ID. Are you trying to open a P&ID drawing in AutoCAD Mechanical?
Pat Jenakanandhini
Product Manager
Plant Solutions - AEC
Pat Jenakanandhini
Product Manager
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-19-2012 07:24 AM in reply to:
rrui00
Sorry, you are right, the name of the software is AutoCad Mechanical 2011.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-19-2012 04:07 PM in reply to:
rrui00
Are you sure you're not in Paper Space and the P&ID Lines are in Model Space?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-19-2012 04:37 PM in reply to:
rrui00
It doesn't matter what version you save it as. P&ID is a custom object which is designed not to be able to modified from another software (for data integrity). You'll need to export it to autocad using 'exporttoautocad' command.
AutoCAD Mechanical is a bit loose on this, you can modify a mechanical object using another software but it will prompt you to reset back to the original drawing once you open it back using AutoCAD Mechanical.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
