• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    attila_vallyon
    Lost size property, P&ID 2013
    314 Views, 4 Replies
    11-23-2012 05:04 AM
    Hi!
    From time to time I loose the size property of an inline element. Such as a valve or just a flanged connection. I should see for example 1" from a size tag, but I see only a dot. If I move the valve symbol on a pipeline a little bit than the size properties reappear and I get the proper size again.
    But I do not want to do this again for all valves in a PID.
    Any ideas?
    Attila Vallyon
    Please use plain text.
    attila_vallyon
    Re: Lost size property, P&ID 2013
    12-04-2012 02:03 AM in reply to: attila_vallyon
    I am a bit disappointed!
    I have not got a single reply.
    This forum is not helpful anymore.
    Attila Vallyon
    *Expert Elite*
    Rave.Tam
    12-04-2012 02:45 AM in reply to: attila_vallyon
    Try the tools on my website. There is a way to batch update the acquisition value.
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    attila_vallyon
    12-04-2012 04:50 AM in reply to: Rave.Tam
    Thanks for the reply!
    I hope this helps! But I am not sure how to use this tool. Can you give a small description?
    Thanks in advance!
    Attila Vallyon
    *Expert Elite*
    Rave.Tam
    12-04-2012 05:09 AM in reply to: attila_vallyon
    This tool allows you to select drawings from a built in browser, and batch run some specific commands on these drawings at once. One example is updating the size on valve (if it is not updated) on all the drawings.
    1. Download the zip file on the download page
    2. Follow the installation instruction on the same page
    3. Check out post on this tool here
    The command that you need to run is Update Acquisition and Refresh Annotation. As usual, backup your files before attempting this.
