• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Accepted Solution
    Linetype Scale between Model & Paper Space
    1129 Views, 3 Replies
    02-16-2012 01:47 PM
    The problem that I am running into is that the linetype scale does not match up between Model and Paper Space. I set ltscale to .75 so that I didn't have to have instruments that far away from each other for the Electrical signal line to show it being dashed. I also did that for the Pneumatic signal line. In model space with the Electrical line being .75 long, it would show the dashed line having 3 segments. I would check that in Paper space and it would only have 2 segments.
    Any help would be greatly appreciated.
    Eric
    See Attached file for visual reference. Top image is from Model space, Bottom image is from Paperspace
    Please use plain text.
    *Expert Elite*
    Rave.Tam
    Re: Linetype Scale between Model & Paper Space
    02-16-2012 06:44 PM in reply to: hinde
    psltscale to 0?
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    Valued Contributor
    02-20-2012 08:16 AM in reply to: Rave.Tam
    It seemed to work right after i tried it for the first time, but now it doesn't seem to work.
    Valued Contributor
    02-20-2012 09:39 AM in reply to: hinde
    It works once i set the variable to "0" and then close the drawing and re-open it.
