• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Issue casting DOUBLE DataType in PnPRow Column Object
    186 Views, 0 Replies
    07-20-2012 04:08 PM
    I'm have problems casting a PnPRow column object to type double. I get a "Specified cast is not valid." error message thrown. However, I have no problems casting a PnPRow to type long (for PnPID) or string (for String data types in P&ID Class Definitions). Could the casting error be due to the value being empty? I do a check for (row[c] == null) but it is never null. Here are examples that work:
    PnPRow row;
    //After obtaining PnPRow...
    int pnpid = (int)row[0]; //PnPID column, works fine
    string tempstr = (string)row[c];
    double num = (double)row[c]; //Error!
     As background, here is the full code for anybody on here to test and hopefully answer my question:
    PlantProject proj = PlantApplication.CurrentProject;
    ProjectPartCollection projParts = proj.ProjectParts;
    PnIdProject pnidProj = (PnIdProject)projParts["PnId"];
    DataLinksManager dlm = pnidProj.DataLinksManager;
    PnPDatabase db = dlm.GetPnPDatabase();
    PnPTables pnpTbls = db.Tables;
    PnPTable aTbl = pnpTbls["Instrumentation"];
    PnPColumns cols = aTbl.AllColumns;
    List<DataType> dataTypes = new List<DataType>(50);
    List<string> colNames = new List<string>(50);
    List<int> colNums = new List<int>(50);
    string cmdVals, cmdFlds, tempstr, typestr;
    string cmdText = "CREATE TABLE [INSTRUMENT LIST] (";
    int j = 0;
    foreach (PnPColumn col in cols)
    	tempstr = col.Name.Replace(' ', '_') + '_'; //Replace spaces with '_' and append '_' to make field names unique
    	typestr = col.ColumnType.Name;
    	switch (typestr[0])
    		case 'I':
    			cmdText += tempstr + " LONG,";
    			dataTypes.Add(DataType.Long);
    			break;
    		case 'D':
    			if (typestr[1] == 'a')
    				cmdText += tempstr + " DATETIME,";
    				dataTypes.Add(DataType.Date);
    			else
    				cmdText += tempstr + " DOUBLE,";
    				dataTypes.Add(DataType.Double);
    			break;
    		case 'S':
    			cmdText += tempstr + " CHAR(255),";
    			dataTypes.Add(DataType.String);
    			break;
    		default:
    			txtFeedback.Text += "Unknown data type '" + typestr + "' found with column " + col.Name + "; defaulting to string.";
    		break;
    	cmdFlds += tempstr + ',';
    	colNames.Add(tempstr);
    	colNums.Add(j);
    	cmdVals += '@' + tempstr + ',';
    	j++;
    cmdVals = cmdVals.Substring(0, cmdVals.Length - 1);
    cmdFlds = cmdFlds.Substring(0, cmdFlds.Length - 1);
    string xlFile = "C:\\temp\\output.xlsx";
    if (File.Exists(xlFile))
    	File.Delete(xlFile);
    if (File.Exists("C:\\temp\\blank.xlsx"))
    	File.Copy("C:\\temp\\blank.xlsx", xlFile);
    using (OleDbConnection xlCon = new OleDbConnection("Provider = Microsoft.ACE.OLEDB.12.0; " +
    				"Data Source = " + xlFile + ";Mode=ReadWrite;" +
    				"Extended Properties='Excel 12.0;HDR=YES;'"))
    	xlCon.Open();
    	OleDbCommand xlCmd = new OleDbCommand(cmdText.Substring(0, cmdText.Length - 1) + ')', xlCon);
    	xlCmd.ExecuteNonQuery(); //Create [INSTRUMENT LIST] table
    	xlCmd = null;
    	PnPRow[] rows = aTbl.Select();
    	foreach (PnPRow row in rows)
    		xlCmd = new OleDbCommand("INSERT INTO [INSTRUMENT LIST](" + cmdFlds + ") values(" + cmdVals + ')', xlCon);
    		j = 0;
    		foreach(int c in colNums)
    			if (row[c] == null)
    				xlCmd.Parameters.AddWithValue("@" + colNames[j], DBNull.Value);
    			else
    				switch (dataTypes[j])
    					case DataType.Date:
    						DataType tempDT = (DateTime)row[c];
    						xlCmd.Parameters.AddWithValue("@" + colNames[j], tempDT);
    						break;
    					case DataType.Double:
    						double tempDbl = (double)row[c];	// ***THIS CRASHES***
    						xlCmd.Parameters.AddWithValue("@" + colNames[j], tempDbl);
    						break;
    					case DataType.Long:
    						tempLong = (long)row[c];
    						xlCmd.Parameters.AddWithValue("@" + colNames[j], tempLong);
    						break;
    					//case DataType.General:
    					//case DataType.String:
    					default:
    						tempstr = row[c].ToString();
    						if (tempstr.Length > 0)
    							xlCmd.Parameters.AddWithValue("@" + colNames[j], tempstr);
    						else
    						break;
    			j++;
    		xlCmd.ExecuteNonQuery();	//Insert a row of data into the [INSTRUMENT LIST] table
    	xlCon.Close();
    Is it failing because the double value is empty? If so, how would I check for an empty value before assigning to [double num]?
    Thanks in advance.
    Please use plain text.
