• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Contributor
    tgwestbrook
    Instrument bubble text wipeout not printing
    346 Views, 4 Replies
    12-12-2011 02:29 PM
    I have run into a consistent problem in getting the wipeouts that are part of instrument bubbles to print.
    They display properly on the screen, though when I print, or hit print preview they dissaprear.  I have attached a screen shot and a printed PDF of a bubble.
    I have tried different plot styles, various printers and drivers,  I have checked the common wipeout problems (printer raster settings, wipeout layer on non-plot, 'scale lineweights' selected on plot, draw order, etc)
    Also:  If I use 'explode' on a tag, turing it into a block reference, the wipeouts work.  Only when it is a dynamicasset are the wipeouts failing for me.
    Has anyone else run into this problem, or have any ideas on what the problem could be?
    Please use plain text.
    Product Support
    jason.drew
    Re: Instrument bubble text wipeout not printing
    12-14-2011 08:22 AM in reply to: tgwestbrook
    Is this issue on AutoCAD P&ID 2011 or 2012?
    Thank you,
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Active Contributor
    tgwestbrook
    12-14-2011 08:54 AM in reply to: jason.drew
    This is on 2012, runnign the Plant Design Suite.  So the actual program is P3D, not the stand alone P&ID.
    Product Support
    jason.drew
    12-16-2011 03:40 PM in reply to: tgwestbrook
    I have logged this issue with development and they are looking into the problem.
    Thank you,
    Jason Drew
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    tgwestbrook
    12-19-2011 05:58 AM in reply to: jason.drew
    Has anyone else experianced this problem, or been able to replicate it?
