• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Tee.Dee
    How do I change default value of Property '*Type'
    408 Views, 3 Replies
    02-14-2013 07:10 PM
    For example under
    Project Setup > P&ID Class Definitions > Engineering Items > Equipment > Mechanical Drivers > Motor
    I want to change the 'Default Value' of the Property named *Type.  Is it possible to make the default anything other that what is in the pulldown list? Am I able to create a custom list somewhere?
    Thanks.
    Please use plain text.
    Valued Contributor
    Betreff: How do I change default value of Property '*Type'
    02-15-2013 12:36 AM in reply to: Tee.Dee
    myby you shoud read the help
    cw
    Active Contributor
    georgeendrulat
    Re: How do I change default value of Property '*Type'
    02-15-2013 05:31 AM in reply to: Tee.Dee
    Project Setup > P&ID Class Definitions > Engineering Items > Equipment > Mechanical Drivers > Motor --> Click on "List" under "Property Type", while it is selected on the very right hand side click "Edit...".  From there you can modify the list.  Once you have modified the list to your liking, whatever you choose it to say under "Default Value" will be the default value.
    Valued Contributor
    Tee.Dee
    03-03-2013 02:47 PM in reply to: Tee.Dee
    Sweet, thanks for the help!
