AutoCAD P&ID
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Flow Arrows in both directions ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is it possible to have arrows to show flow in both directions?
As in an equalizer line or crossover line?
Mark
Autodesk Plant 3D Premium 2012
Autodesk MEP 2012
HP 3.2 Mhz CPU 16 ram
1TB 7200 rpm SATA 3Gb/s hard drive
2GB DDR3 NVIDIA GeForce GT 530
HP 2311x 23" LED Monitor
Re: Flow Arrows in both directions ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
my understanding is that if no flow arrow is present then the flow is assumed to be able to go both ways
but to answer your question...the flow arrows are placed manually and the direction can be controled with the blue triangle grip when selected, so i dont see why you couldnt actually place them (even though this is not ussually considered normal practice.
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
... make an new Symbol whit the "wrong" directon it is not right, but it works
cu
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
richos69,
I am running 2012 & arrows are directional to the direction you generate the line. But you can pick the line then right click for OSM & select "schematic Line Edit" then "Reverse Flow". As I now notice, I can manually place an arrow & then "rotate it to get the 2 bi-directional arrows.
Thanks.
Mark
Autodesk MEP 2012
