• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Valued Contributor
    Heckmeck
    Accepted Solution
    Exclude Objects from Database
    388 Views, 3 Replies
    08-10-2012 03:46 AM
    Hi Everyone,
    I have a drawing with several symbols that serve as a caption.
    For example in the upper right corner of the drawing, I show some special symbols with a description of them or some line types with their respective explanation.
    Unfortunately, these symbols appear in the datamanger, since I added them via die tool palette and they are PID symbols.
    I tried to add the caption to the *.dwt (drawing template), but you cannot add pid symbols there. (I produce a crash everythime I try...)
    Is there an easy work around, to not show certain objects in the datamanager?
    In a way, I would like to make some objects "stupid"
    Best regards!
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Exclude Objects from Database
    08-10-2012 03:41 PM in reply to: Heckmeck
    Explode them.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Contributor
    Heckmeck
    08-12-2012 10:38 PM in reply to: Heckmeck
    Thanks for the trick! Sometimes it can be so easy!
    For those you read this: I had to type "._explode" in order to make the explode command work...else I got "unknown command"
    Exploding blocks works great here, but I can't explode my pipes (mostly multilines/slines).
    I tried with "pedit" but that doesn't work since mine are Slines.
    I also tried with "flatten", but my colors will be lost if I use this command.
    Do you have the trick for this one, too?
    Thanks!
    *Expert Elite*
    Rave.Tam
    08-12-2012 11:31 PM in reply to: Heckmeck
    blocking those objects (sline as well) will also exclude them from the data manager. But u'll have problem editing the block later because editing P&ID objects in block editor is not supported.
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
