AutoCAD P&ID
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Displaying area number for a valve
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
164 Views, 3 Replies
12-05-2007 08:41 AM
I would like to display the area number for a valve or other component on a drawing. I find I can do this easily enough for individual instrumentation tags. But how do I edit the tag that goes with a particular piece of equipment i.e. where can I get at and edit the "Field mounted Discrete instrument_Styleblock" for example
*Jorge Lopez
Re: Displaying area number for a valve
Options
- Highlight
- Email to a Friend
12-05-2007 09:28 AM in reply to:
fx2032
Steps:
Use the EDITPROJECT command or right-click the project in the Project
Manager and select properties.
Open up P&ID Class Definitions, EngineeringItems, Instrumentation,
GeneralInstrumentSymbols, FieldMountedDiscreteInstrument in the tree view on
the left.
At the top under "Class Settings: FieldMountedDiscreteInstrument" select
Edit Block...
You will then be placed in the block editor and see a dynamic block
definition. Two things to note here:
1. Toolbar with a single icon to launch the Assign Annotation Format dialog.
2. Attribute definitions such as #(TargetObject.Type)
Refer to the AutoCAD P&ID documentation for an explanation of using the
Assign Annotation Format dialog. You can use it to modify the attdef
expression that is evaluated by the program.
Once you are done with your edits, close the block editor (ie. BCLOSE), save
your changes, and hit OK all the way out of project setup.
Hope this helps.
Jorge
"fx2032" wrote in message news:5793201@discussion.autodesk.com...
the left.
Edit Block...
Hope this helps.
Jorge
Options
- Highlight
- Email to a Friend
12-05-2007 10:11 AM in reply to:
fx2032
Hey, many thanks for that reply!
I have actually managed to do this, as you have said. But the problem is I would like to edit the bubbles that go with... say a hand valve, so after converting it to a control valve I would also like IT to have an area number on the schematic.
The problem is I cant see where I can get at the tag bubbles associated with such "inline assets" For these the "edit block" only edits the symbol for the asset and not the bubble. And they do not seem to share the same bubbles as the separate instrumentation tags!
*Jorge Lopez
Options
- Highlight
- Email to a Friend
12-06-2007 12:51 PM in reply to:
fx2032
If I understand correctly, then you are looking for the annotation blocks
and these are a bit tricky to find. Go into project setup and find the class
whose's annotation block you want to modify. Select the annotation style
from the drop down combo box in the bottom right. If the Edit Block...
button continues to be disabled then click on the parent node of that class
in the tree view on the left and repeat until Edit Block... is enabled. That
is the location in the tree where it is defined and all classes below that
node get it. If you want to a add new style then you can do so at any level.
Hope this helps.
Jorge
"fx2032" wrote in message news:5793350@discussion.autodesk.com...
on the schematic.
Hope this helps.
Jorge
on the schematic.
