• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Member
    Creating Typicals and having each item have its own identity in data manager?
    167 Views, 2 Replies
    06-28-2012 12:37 PM
    Is there a way to create "typical" of a piece of equipment that will be used over and over in the project, but each piece of equipment needs its own identity to show up in the data manager and still only show the one typical for that type of equipment?
    Kim
    Please use plain text.
    Active Contributor
    Re: Creating Typicals and having each item have its own identity in data manager
    06-29-2012 01:34 AM in reply to: kgroskopf
    Spoiler
    try wblocks ?
    Plant Design software consultant at Greenock CAD service
    Product Support
    06-29-2012 04:35 PM in reply to: kgroskopf
    As far as Data Management is concerned each piece of Equipment is unique. There are many different variables that are associated with equipment when being used in reporting. So, P&ID treats anything made under equipment as "1" piece of equipment. So, duplication is not an option. However, depending if you don't want or care about information being in a report, there is another option. You could place the equipment in the "Inline Assets-->Piping Specialty Items". For example you have a Process Line starting at a Tank and ending at a Tank. You would add a Tank symbol to the Piping Specialty Items. Add a new Tag Format to just take on the Description of the Tank you created. Add the new created Tank to your palette. Now, when you draw a process line and put a Tank at each end of the process line. The line will read From: TANK, To: TANK. Just keep in mind these Tanks will not show up on an equipment report.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    Autodesk, Inc.
