AutoCAD P&ID
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Convert to P&ID Object problem
- Highlight
- Email to a Friend
when using the Convert to PID Object command it does not allowed you to select items do not have a symbol in project manager?
Re: Convert to P&ID Object problem
- Highlight
- Email to a Friend
I think you'll find that you can only select assets which have a GraphicalStyleName property defined. I suspect that it looks up the default symbol properties from this symbol - it needs to lookup connection type, tag requirements etc from somewhere.
Andy
- Highlight
- Email to a Friend
That is a good restating of the Problem.
The question is how to fix or work around said problem. In most cases if a graphical style already existed, you would not need to convert-to-P&ID-object. -And creating an empty block for every class seems prohibitively time consuming and difficult.
- Highlight
- Email to a Friend
There is no real "fix" for that, because it behaves this way by design. You could create a default block and assign this block to all the "blank" classes.
Not a real solution I know.
Carsten
- Highlight
- Email to a Friend
I will log a feature request with our developers to give the user the ability to create new class symbols using the "Convert to P&ID Object" command.
At the moment you will need to workaround this limitation by creating a symbol for the class before using the "Convert to P&ID Object" to add a new symbol.
Dan
Dan Scales
Product Support Specialist
Autodesk, Inc.
