• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Convert to P&ID Object problem
    259 Views, 4 Replies
    07-18-2012 05:55 AM
    when using the Convert to PID Object command it does not allowed you to select items do not have a symbol in project manager?
    Please use plain text.
    Valued Contributor
    andy.davis
    Re: Convert to P&ID Object problem
    07-18-2012 09:04 AM in reply to: thebearjed
    I think you'll find that you can only select assets which have a GraphicalStyleName property defined.  I suspect that it looks up the default symbol properties from this symbol - it needs to lookup connection type, tag requirements etc from somewhere.
    Andy
    Active Contributor
    tgwestbrook
    07-18-2012 10:22 AM in reply to: andy.davis
    That is a good restating of the Problem.
    The question is how to fix or work around said problem.  In most cases if a graphical style already existed, you would not need to convert-to-P&ID-object.  -And creating an empty block for every class seems prohibitively time consuming and difficult.
    Active Contributor
    07-26-2012 08:43 AM in reply to: tgwestbrook
    There is no real "fix" for that, because it behaves this way by design. You could create a default block and assign this block to all the "blank" classes.
    Not a real solution I know.
    Carsten
    Product Support
    07-27-2012 01:58 AM in reply to: thebearjed
    I will log a feature request with our developers to give the user the ability to create new class symbols using the "Convert to P&ID Object" command.
    At the moment you will need to workaround this limitation by creating a symbol for the class before using the "Convert to P&ID Object" to add a new symbol.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
