• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    Re: Control Valves substitutions problem
    01-07-2013 03:12 AM in reply to: hiddink
    i have got the same problems with the control valves. Of course deleting of this substitution file works, but changing every cv that has the same issue is very unproductive and waste of time.
    Is there any other solution to this problem?
    Please use plain text.
    Valued Contributor
    Tee.Dee
    02-11-2013 06:22 PM in reply to: MK531977
    This fix didnt work for me either.  This program is supposed to save time instead it just seems to create endless problems that have no fix.
    Discussion_Admin
    02-27-2013 05:46 AM in reply to: iq206
    I´m so tired of this problem. I had it a couple of months ago, and fixed it by manually remove and add controlvalves.
    Now it has appeared again and I can't just make it for hundreds of valves. It is not just possible in projects.
    Autodesk: You must make a product that keep data consistent!!! It is the single most important thing with a P&ID processinformation software!
    //Johan
