• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    iq206
    Control Valves substitutions problem
    1044 Views, 12 Replies
    09-19-2012 04:22 AM
    Hi
    As in my subject I have some problems with control valves.
    When I add new CV everything is OK, i can change actuators orz valve type, but during my project something happaned and I can't make any changes with CV (see attached file).
    Plese Help.
    Please use plain text.
    Member
    Re: Control Valves substitutions problem
    09-20-2012 08:16 AM in reply to: iq206
    I have this same problem, when inserting a CV the substitution pallet works as expected, until the drawing is closed. Upon reopening, the CV substitution will only yield options from inline instrument class, both for the body and the actuator. This is the case for all my CVs in both P3D 2012 and P3D 2013
    09-26-2012 06:46 AM in reply to: nfproductions
    It happens to me to. Does AutoDesk intend to fix the preoblem or are they just letting us stick with it?
    //Johan
    Active Member
    iq206
    09-26-2012 06:52 AM in reply to: iq206
    Autodesk do NOTHING, but I'm used to it, and most problems solving itself.
    This problem is still un solve and now I don't have much time to fix it.
    Distinguished Contributor
    craig.wood
    09-26-2012 04:59 PM in reply to: iq206
    I have a similar problem with control valves as well. The substitution menu often reverts back to the first class of inline instruments instead of valve bodies or actuators.
    Active Member
    iq206
    09-26-2012 11:21 PM in reply to: iq206
    Ok, but how to fix it?
    Valued Contributor
    Tee.Dee
    11-15-2012 04:42 PM in reply to: iq206
    This thread is almost a year old now, Does anybody have a solution to this problem? Im using 2013
    Member
    12-12-2012 11:14 PM in reply to: Tee.Dee
    I got the following answer from Autodesk
    Try deleting the SubstitutionPalettes.xml from the root of the project.
    After you have done this reopen the project and place a new control valve to check the substitution palette.
    Note:
    Existing contral valves that have the issue may need to be replaced in the drawing.
    Martijn
    Active Member
    iq206
    12-12-2012 11:50 PM in reply to: hiddink
    I try this solution and nothing. But honestly, this solution is like my IT service team guy practice, computer restart for every problems.
    Member
    12-12-2012 11:52 PM in reply to: iq206
    For me it worked. Didn't see the problem anymore
