• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Distinguished Contributor
    craig.wood
    Continue Sline Group vs. New Sline Group (Default)
    224 Views, 2 Replies
    08-14-2012 07:55 PM
    Is there any way to change the default setting on slines for branches off of a header? By default, the sline group is continued when drawing a branch from a header. To create a new group, you must type "n" and then press the enter key before routing your branch line. Is there a registry setting or something of that sort to change the default to "new sline group" from "continue sline group"?
    Craig
    Please use plain text.
    Product Support
    Re: Continue Sline Group vs. New Sline Group (Default)
    08-16-2012 03:57 AM in reply to: craig.wood
    There is no variable that allows branch pipes to automatically be routed as a new pipe line group.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    craig.wood
    08-16-2012 09:41 AM in reply to: DanScales
    Thank you for the info Dan.
    Craig
