• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Changing the name of a P&ID 2012 project
    361 Views, 5 Replies
    12-19-2012 09:04 AM
    Hi All
    is there away to cahnge the name of an already running project that contains P&IDs and data
    Jacob Eilon
    Please use plain text.
    Valued Mentor
    ybogdanov
    Yes, is posible. Yo need: 1. Change the name of folder 2....
    12-20-2012 12:25 PM in reply to: eiloneng
    Yes, is posible. You need:
    2. Change the paths in Project.xml
    3. Change description and name of project in all dcf files
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Product Support
    Re: Changing the name of a P&ID 2012 project
    12-21-2012 02:54 AM in reply to: eiloneng
    As Yury says in the previous post, it is possible to change the project name.
    To edit the name in the DCF files you need to use an SQLite editor of some kind. There are various ones available to download online.
    The table that contains the project name that needs to be edited is called "PnPProject".
    Please note that doing the name change in this was is officially supported and the recommended way would be to create a new project using the required name and copy the drawings from the old project to the new project.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    01-04-2013 01:32 AM in reply to: eiloneng
    Thanks for the answers
    1. I could not find in the project PnPProject.dcf file in the project folder (Aurocad P&ID 2012)
    I2. Is there an editor you would reccomend
    Jacob Eilon
    *Expert Elite*
    Rave.Tam
    01-04-2013 07:46 PM in reply to: eiloneng
    You'll need to modify all the dcf files (iso, ortho and etc) inside the project (4 or 5 of them). Here's a couple of free editor which i recommends on my blog
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    Valued Mentor
    ybogdanov
    01-05-2013 05:47 AM in reply to: eiloneng
    Jacob Eilon
    PnP Project is not file of project folder. It's the table which stay in each dcf file. You need to open ProcessPower.dcf file with any SQLite editor and modify the table PNP Project.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
