• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Member
    Change the Default Nozzle Type or get ride of Nozzle
    132 Views, 2 Replies
    03-25-2008 05:40 PM
    Hi, there,
    When I connect a line segment to an equipment item (such as a tank), a flanged nozzle will be added automatically as the default one. If I don't want nozzle automatically added when I make connections, what I should do? How I can set single line nozzle as the default one?
    Thanks for your suggestions and help in advance,
    Colin
    Please use plain text.
    *Jorge Lopez
    Re: Change the Default Nozzle Type or get ride of Nozzle
    03-26-2008 06:47 AM in reply to: Colin.Han
    Hi Colin,
    In Project Setup, under P&ID Class Definitions, find the equipment who's
    nozzle setting you want to change. After clicking on the appropriate node in
    the tree view, select the Edit Symbol... button on the right pane of the
    dialog box. A new Symbol Settings dialog box will come up. Under the Other
    Settings group, you can set whether nozzles should be used and if so which
    nozzle style to use.
    Jorge
    "ColinH" wrote in message news:5885360@discussion.autodesk.com...
    Hi, there,
    Colin
    Member
    03-26-2008 08:29 AM in reply to: Colin.Han
    Thanks, Jorge, for your help.
    Colin
