• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Accepted Solution
    Can you help. I do not resolve this error
    412 Views, 1 Replies
    01-15-2013 01:22 AM
    good morning
    to make the validation of the PID error I mark these lines,   always put the + (not connected). Delete the lines I restart and you're always the same, with the + and not with the dot indicating that this connected
    Where is my mistake to draw?
    best regards
    joaquin
    Please use plain text.
    Active Contributor
    georgeendrulat
    Re: Can you help. I do not resolve this error
    01-16-2013 05:28 AM in reply to: joaquinr
    Try moving/stretching the lines endpoint by osnap: "endpoint" to the offpage connectors node osnap:"Node".  This will connect the line to the off page connector.  When connecting one connector to another make sure you are connecting a "to" connector to a "from" connector.  You can tell which is which by the direction of flow on the line connected to the connector itself.
    Hope this helps.
