• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    JanHarink5665
    Accepted Solution
    Calculated properties manager Autocad PnID
    598 Views, 1 Replies
    01-20-2013 02:51 AM
    Hello, i am having trouble with the Calculated Properties Manager in PnID. I want to create a new propertie combined from 3 other Project Properties and a General Property.
    I have attached an image from the Calc Prop Manager. I can't get it done. Tried also the the following link to Autodesk;http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21024206&linkID=11705365
    Is a more detailed Help available for this item. I have tried it on a project, since that time the project is corrupt and crashes each time i start the Project Setup Manager.
    Regards, Jan
    Please use plain text.
    Valued Contributor
    Betreff: Calculated properties manager Autocad PnID
    01-21-2013 02:54 AM in reply to: JanHarink5665
    your link , are the only help, and the anserw is in there
    Click the concatenating symbol (||).
    kilck your first  part then put in || then the next part . BUT if one of them is not fillt you will see nothing
    cw
