• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Contributor
    georgeendrulat
    Automatic two way link between excel & data manager?
    389 Views, 3 Replies
    01-23-2013 07:38 AM
    Is there a way to automatically update data manager data with an external excel file without the tedious import/export?
    If there is not, where is the data manager's data being pulled from? The drawing itself? An external database?  It looks like when I modify a P&ID object it interally modifies Autodesk.processpower.pnidobjects.whatever, but where is that data actually located? I can open and view the processpower.dcfx file and look at the relationship tables, but can't figure out where the actual data values are.  Is that just the location of the object deffinition and the value is located elsewhere? Within the drawing itself?
    If it is within the drawing itself, is there a database editing software that would allow my engineers to view and modify that information directly?
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Automatic two way link between excel & data manager?
    01-23-2013 03:30 PM in reply to: georgeendrulat
    The data is stores in the .dcf files.  the import and export are used to manage the changes, by design. The structure is such that I don't recommend people accessing the data.   You can use SQLite expert peraccess for direct access.  Our blog has links to it.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Active Contributor
    georgeendrulat
    01-24-2013 09:32 AM in reply to: dave.wolfe
    Looked into SQlite expert personal, opened the processpower.dcf, scrolled down to one of the _PNP entries, clicked on "Data" on the right hand side, poof, there it was.  Great stuff.
    Now I just need to figure out if this is something that is more useful than dangerous.  If multiple people can be editing the .dcf file while others are updating the dwgs.  If there is a way to associate that internal information to a formatted external editor so no one accidently deletes something they shouldn't.  Possibly a realtime link to an external editor or even excel.
    Thank you very much for the help and information, I appreciate it.
    Active Contributor
    georgeendrulat
    01-24-2013 10:07 AM in reply to: georgeendrulat
    Links:
    SQlite Expert Personal
    SQLite ODBC Driver
    SQLite OleDB Wrappers
    SQLite ActiveX Wrapper
    SQLite for excel
    A lot of options there for editing the .dcf files outside of Autocad P&ID.
