• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Distinguished Contributor
    craig.wood
    Auto-Nozzle Died -- SOS
    374 Views, 3 Replies
    04-09-2012 03:25 PM
    I've run into yet another snag in setting up AutoCAD P&ID. I was adding different nozzles today and for no apparent reason, the auto-nozzle feature stopped working. I thought it may have been because I had renamed a few nozzles (which would make the program not very robust if that were the case), but after going back and changing them back to the default settings, nothing had changed. I've tried connecting pipe to several different types of equipment as well, but to no avail.
    Please help, I need to have this project setup finished by next week and have this issue along with 2 other major outstanding issues (from earlier post: http://forums.autodesk.com/t5/AutoCAD-P-ID/Valve-Substitution-amp-Annotation-Problem/td-p/3399851).
    I've attached my projSymbolStyle.dwg and project.xml file if anyone is up to the task of troubleshooting what might be the reason my project files seem to be having these major issues.
    Thanks in advance for your time,
    Craig
    Please use plain text.
    craig.wood
    Re: Auto-Nozzle Died -- SOS
    04-10-2012 05:55 PM in reply to: craig.wood
    Update 4/10/12
    I may have a clue as to what broke my auto-nozzle feature, but need help restoring it.
    I ran auditproject on projSymbolStyles.dwg and received the following notification:
    My guess it that I broke the reference to the default nozzle used for the auto-nozzle feature when I renamed the nozzle, namely the "Double Line Nozzle."
    I renamed/changed it back to the out of the box settings, but it still seems that the reference is broken. How can this be fixed so the auto-nozzle feature may be restored?
    Craig
    New Member
    02-27-2013 03:29 PM in reply to: craig.wood
    Hi Craig, Did you find a way to fix the problem, or did you have to throw that project away and start again from scratch?
    craig.wood
    02-27-2013 04:03 PM in reply to: Clive_Murphy
    No resolution ever came for this issue, and I soon thereafter decided to scrap my project setup and start clean due to a couple of other major issues I ran into. It was painful, but I'm glad to have this feature and avoided breaking it a second time. I don't know what kind of timeframe you're looking at, but 2014 ought to be coming out in early April. As for me, I plan on creating a brand new project template from it in hopes that many of the issues I ran into will be addressed in it.
