• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Homskillit
    Assemblies in AutoCAD P&ID??
    1252 Views, 4 Replies
    12-03-2010 01:54 PM
    Another rookie question here but can you build assemblies in AutoCAD P&ID?.  I cant seem to find the assembly enviornment . . . .
    Please use plain text.
    Product Support
    jason.drew
    Re: Assemblies in AutoCAD P&ID??
    12-05-2010 12:38 PM in reply to: Homskillit
    It is possible to create commonly used assemblies in P&ID. What you want to do is create a block for your assembly and add it to the tool palette.
    For example, here is a simple pump instrument loop:
     2320i942760B8131A7ED5
    Steps to create an assembly of this:
    1. Select all of the objects to be included in the assembly
    2. Convert these to a block using the BLOCK command (select a logical insertion point)
    2324i971045309D86CF10
    3. Save the drawing, then drag the block over to the tool palette
    2326i2FDA1FD9B794D1E4
    To place the assembly in a drawing:
    1. Use the tool palette just as you would for any symbol
    2. Select the assembly and use the EXPLODE command
    3. The assembly items are now placed and ready to use
    One thing to note, on any tagged objects such as equipment or instruments make sure you leave the item tags blank before creating the assembly. That way you can place the assembly over and over and just assign the tags once it's placed in the drawing.
    Jason Drew
    Support Specialist
    Product Support
    Autodesk, Inc.
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
    Homskillit
    12-06-2010 08:45 AM in reply to: Homskillit
    Thank you very much for that.  Actually, what I was looking for was the 3D assembly enviornment.
    I was able to create a 3D assembly using blocks but I couldnt find the "Insert Components" or other assembly commands.
    I was using the acad3D template but I wanst able to ind any assembly commands.
    Does AutoCAD P&ID have 3D assembly capability?
    Distinguished Mentor
    jaich
    12-06-2010 03:46 PM in reply to: Homskillit
    You'll want Inventor.
    Valued Contributor
    Heckmeck
    10-18-2012 12:33 AM in reply to: jason.drew
    One additional question on assemblies:
    When I insert the assembly in my tool palette, I can use it over and over again.
    But if I want to change one object in the assembly, all my drawings won't recognize the changes I made.
    (Even if I do not explode the assembly)
    Can this be achieved somehow?
