• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Active Member
    rtrayes1
    Annotation Changes Unexpectedly
    433 Views, 3 Replies
    12-08-2010 08:38 AM
    I am having problems with my valve annotations changing when I go into Project Properties.  When I place a valve onto a primary line segment which already has a size assigned to it, the size of the pipe appears above the valve.  Now, when I go into Project Properties and exit ( it doesnt matter if i hit cancel, apply, or ok) my annotations chenge.  Is this a problem with the project, the drawing, or the template?  I am currently using a custom template file to start my P&ID drawings.  I tried to customize some properties, but it has been a while since I used the program, so I am unsure what I did.  Any help is great.
    Ryan
    Please use plain text.
    Active Member
    rtrayes1
    Re: Annotation Changes Unexpectedly
    12-08-2010 10:01 AM in reply to: rtrayes1
    One thing I noticed is that this started happening in this project after I edited the block for off-page connectors.
    Employee
    IanMatthew
    12-14-2010 11:32 AM in reply to: rtrayes1
    Can you send us some examples of what is happening
    Ian Matthew
    Techinal Marketing Manager, Plant Solutions
    boswald
    12-29-2010 07:34 AM in reply to: IanMatthew
    I just posted a similar problem, then found this post, my post has example images attached.
    AutoCAD P&ID 2011 Annotation Update Problem
    I had created my own off page connectors, and P&ID objects.  I am finding the customization to be problematic - goofy things happening.
    Brad
