• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    nikoR
    Accepted Solution
    Acquisition rules break often with no reason
    987 Views, 6 Replies
    10-10-2012 02:44 AM
    Fields with Acquisition rules get empty fields occasionally even if there is data in fields it acquires from (and they are connected correctly). This happens especially when EXPORTTOAUTOCAD is used, but regularly also without it.
    Also, wirh Windows 7 the user cannot utilize the "Acquisition Property Update Utility" because netload doesn't function any more (it did with Win XP). This can be overcomed by modifying  acad.exe.config -file but not feasibel solution with dozend of users with limited privilegies to modify that file.
    So:
    1) Why Acquired fields get ompty fields with no apparent reason?
    2) Could REFRESHACQPOPERTY -command cannot be standard feature in PID2013 - if not - why?
    Ideas Appreciated - Thanks!
    Please use plain text.
    Product Support
    Re: Acquisition rules break often with no reason
    10-12-2012 02:36 AM in reply to: nikoR
    To prevent the NETLOAD error the DLL should be placed in the install directory of Plant or P&ID rather than on a network drive.
    I hope this helps.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    nikoR
    10-12-2012 04:56 AM in reply to: DanScales
    Thanks; this solved that netload-problem. Actually our designers cannot modify the contents of folder C:\Program Files\Autodesk\AutoCAD P&ID 2012 – English either because of corporate IT security limitations. But the .dll file can be copied to c:\Temp –folder and netload works from there.
    Member
    hung.tam
    10-29-2012 08:52 AM in reply to: nikoR
    Check out if this tool helps. There's a plugin for updating acquisition value.
    http://lazcad.com/2012/10/lazplantbrowser-v0.2beta
    You can also check out the way i build the package using autoloader format so it can be loaded to the software without netload.
    nikoR
    03-05-2013 12:59 AM in reply to: hung.tam
    Thanks - that sems to be handy tool! I noticed though that if I select "Zoom All" in addition to other commands, it seems it's not doing the other selected updates, e.g. Refresh Acquisition. But if Zoom All is not selected, it really updates the acquisitions. Thanks you!
    Also Autodesk supplied hotfix to the EXPORTTOAUTOCAD-problem.
    *Expert Elite*
    Rave.Tam
    03-18-2013 08:00 AM in reply to: nikoR
    Make sure you're using the new bug fix version here :smileyhappy:
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    nikoR
    03-21-2013 04:16 AM in reply to: Rave.Tam
    Thanks Rave;
    I'm using the latest version and works like a charm :smileyhappy:
    (Still I think it does not no updates when zoom all is selected.. However, I just don't select it)
