• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    New Member
    ANNO AND DISAPPEARING TEXT
    232 Views, 1 Replies
    01-09-2013 10:16 AM
    I created a new anno for one of the blockS, put the information in and it stays there until I go into the project setup. It disappears when I go back into the drawing.
    Please use plain text.
    Active Contributor
    georgeendrulat
    Re: ANNO AND DISAPPEARING TEXT
    01-14-2013 11:43 AM in reply to: bradley.svoboda
    Can you verify that the block that you are using for the annotation is located somewhere that the drawing can see.  Can you verify that the layer inside the block is 0.  Can you verify that the block is useable on it's own in a non-p&id dwg. Can you verify that the data inputted within the block is there.  I'm thinking it's a block problem not a P&ID problem.
