• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD P&ID
    Member
    Compressor-01
    ACAD P&ID 30 day trial and trying to make something happen ASAP! :)
    414 Views, 2 Replies
    01-31-2011 08:57 AM
    Hello all. I have recently downloaded the 30 day trial in an attempt to prove to my company that we need this valuable tool.
    In doing so, I am attempting to creat some of our needed P&ID's
    I have opened a new file and began by trying to insret a "recipricating compressor" component in the model space directly from the tool pallet. I have chosen the P&ID DIN workspace tool pallet.
    I see all the tools I need, but can not get them to be applied to begin a drawing. I have tried placing a pneumatic line first and then applying the compnent as well to no avail.
    I am sure it is just a matter of the correct process and the correct format.
    Can someone point me in the right direction to get started?
    Thanks!!!
    Please use plain text.
    Distinguished Contributor
    Re: ACAD P&ID 30 day trial and trying to make something happen ASAP! :)
    02-03-2011 08:35 AM in reply to: Compressor-01
    If the software installed correctly, this should be real easy. Pick a piece of equipment on the tool palette using the mouse. Move to the drawing and select an insertion point. Select a line on the tool palette. Then pick a starting point on the drawing and pick the next point as a connection to you piece of equipment.
    If you can't do this, there may be something wrong with your installation.
    Tom
    Employee
    BuddyLegnon
    02-14-2011 08:09 AM in reply to: tom_pe
    heres a tip - watch the online videos first - then dont drop and drag..just click once on the palette then click to place on the dwg area.
    It is the best tool, and do yourself and your company a favor - get an Autodesk onsite demo and make sure the suits are in attendance.
    :smileywink:
    If my post answers your question, please click the "Accept as Solution" button (you must be logged in). This helps everyone find answers more quickly.
