AutoCAD P&ID General
Active Contributor
huanggy
Message 1 of 6 (654 Views)
Accepted Solution
the asset block can't hide the pipe line
654 Views, 5 Replies
06-13-2013 01:09 AM
Hi, Dear All,
Some times the asset block can't hide the pipe line as usual, it's occassionally happened.
Does any one know the reason?
Thanks for any input!
Gengyun
craig.wood
Message 2 of 6 (634 Views)
Re: the asset block can't hide the pipe line
06-13-2013 03:44 PM in reply to: huanggy
Hi Gengyun,
Are you defining connection points within your blocks?
Craig
Active Contributor
huanggy
Message 3 of 6 (631 Views)
06-13-2013 07:06 PM in reply to: craig.wood
Hi, Craig,
Yes, we define the connect point for each asset symbol. and you can see from the drawing, that only one block can't hide the pipe line, others are ok. so it's so strange.
Thanks for you suggestion.
Gengyun
*Expert Elite*
Rave.Tam
Message 4 of 6 (606 Views)
06-19-2013 07:47 AM in reply to: huanggy
This is usually caused by line segment error.
1. Try run audit and fix the drawing.
2. If doesn't work, substitute the line with another type, then substitute it back. (use Right click)
Then move the valve or reinsert it
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Active Contributor
huanggy
Message 5 of 6 (595 Views)
06-20-2013 07:25 AM in reply to: Rave.Tam
Thanks, Rave! We will test as your suggestion.
Member
teoelt
Message 6 of 6 (510 Views)
07-09-2013 12:42 AM in reply to: Rave.Tam
HELLO RAVE, I meat the same problem and have tested your solution. It works in same cases. So I think there needs further way to solute this problem. Anyway thanks for your expedient.
You are not logged in.
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
