AutoCAD P&ID General
Rave.Tam
Message 11 of 14 (249 Views)
Re: "No Target" in annotations due to Batch Script
11-07-2012 05:37 PM in reply to: craig.wood
Can you try to place the plugin in this directory
%AppData%\Autodesk\ApplicationPlugins
You shouldn't need to netload the dll yourself. It should be loaded automatically. Try this command
lazplantbrowser
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
craig.wood
Message 12 of 14 (246 Views)
11-07-2012 05:47 PM in reply to: Rave.Tam
That did it! Thanks!
I'll check it out and come back with some praise soon :smileyhappy:
Craig
Rave.Tam
Message 13 of 14 (240 Views)
11-07-2012 06:59 PM in reply to: craig.wood
great! not sure why it doesn't run from the program files folder.
craig.wood
Message 14 of 14 (238 Views)
11-07-2012 07:02 PM in reply to: Rave.Tam
Actually, it turns out that it was running from the program files after all. I think I just needed to restart the program before it would take effect. I deleted the plugin from the appdata root folder and the plugin is running just fine from the program files folder.
Thanks again!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
