AutoCAD P&ID General
*Expert Elite*
Rave.Tam
Message 11 of 14 (248 Views)
Re: "No Target" in annotations due to Batch Script
11-07-2012 05:37 PM in reply to: craig.wood
Can you try to place the plugin in this directory
%AppData%\Autodesk\ApplicationPlugins
You shouldn't need to netload the dll yourself. It should be loaded automatically. Try this command
lazplantbrowser
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
craig.wood
Message 12 of 14 (245 Views)
11-07-2012 05:47 PM in reply to: Rave.Tam
That did it! Thanks!
I'll check it out and come back with some praise soon :smileyhappy:
Craig
*Expert Elite*
Rave.Tam
Message 13 of 14 (239 Views)
11-07-2012 06:59 PM in reply to: craig.wood
great! not sure why it doesn't run from the program files folder.
craig.wood
Message 14 of 14 (237 Views)
11-07-2012 07:02 PM in reply to: Rave.Tam
Actually, it turns out that it was running from the program files after all. I think I just needed to restart the program before it would take effect. I deleted the plugin from the appdata root folder and the plugin is running just fine from the program files folder.
Thanks again!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
