AutoCAD P&ID General
Message 1 of 5 (465 Views)
nozzels
465 Views, 4 Replies
04-26-2013 07:57 AM
I want to create a equipment with nozzels such as this attachment...I can't create these nozzels with reducer Can you advice me how i can make...
Active Contributor
Message 2 of 5 (380 Views)
Re: nozzels
05-02-2013 01:16 AM in reply to: b060106143
Can you be a bit more specific. What is it you're having a problem with in the process?
//Mikael
Message 3 of 5 (332 Views)
Re: nozzels
05-14-2013 07:38 AM in reply to: mikael
 I want to form these nozzel with reducer Firstly I add a nozzel ,then I add a reducer to this nozzel,but    both of them be  independent so reducer part  of this nozzel is unconnected with equipment...Should I form a new type of nozzel that contain a reducer....thank you for help....
craig.wood
Message 4 of 5 (328 Views)
Re: nozzels
05-14-2013 12:58 PM in reply to: b060106143
We had a similar need, but maybe not exactly what you are requesting. Does the nozzle just need to be a different size than the line that it's connected to? If so, what we did to handle this was to add a property called "Independent Size", and created a separate annotation for it. We did not show a reducer though.
The only other thing that you could do would be to create a new nozzle type that had the reducer graphics built into the block. If you go that route, I would probably also add a property or two for the 'inlet size' and 'outlet size', which you could track in reporting if you wanted to. Also you would want to create an annotation that corresponds to these new properties.
I hope this helps.
Craig
If my post is a solution to your problem, please marked it as Solved below:
Message 5 of 5 (319 Views)
Re: nozzels
05-14-2013 11:46 PM in reply to: craig.wood
thank you for help.... I have added 'inlet size' and 'outlet size
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
