AutoCAD P&ID General
New Member
dalheimer
Message 1 of 2 (439 Views)
connection between blocks/symbols and database
439 Views, 1 Replies
08-31-2012 10:46 AM
Hi all, I`m working with PTC Creo Schematics (former Routed System Designer) for our P&ID’s. We're thinking to change the Software for the P&ID. I’m really surprised which improvement Autodesk made here the last years.
Here my question. Is it possible to insert a block/symbol for example a valve to the pipeline and then choosing the technical specifications from a dropdown list (database). See example selection by size of the valve.
Size | Supplier | Part number |  etc. |
I already found out that I can select different sizes from a preconfigured database but I would like to select for example Size DN100 and all the rest should be filled in automatically. Is that possible without additional software programming.
Thanks a lot.
Employee
KenFauver
Message 2 of 2 (320 Views)
Re: connection between blocks/symbols and database
09-28-2012 09:37 AM in reply to: dalheimer
Hi Dalheimer,
Unfortunately valves in AutoCAD P&ID are not piping specification driven. This is what would allow you to populate said data to you valve.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
