AutoCAD P&ID General
Distinguished Contributor
Tee.Dee
Message 1 of 3 (389 Views)
Where are blocks referenced from?
389 Views, 2 Replies
10-28-2012 05:50 PM
Just wondering where P&ID blocks in a project are referenced from?
If I edit a blocks linework in the project settings iv found that it only changes the block contained in the projSymbolStyle.dwg.  Thats all good but what if i want to add a new block, where does this block need to be saved?
I noticed there are drawings stored under C:\Program Files\Autodesk\AutoCAD P&ID 2013 - English\SymbolLibrary that contain all of the blocks, should I be storing my newly created blocks in one of these drawings?
If so then I would rather have seperate drawings on the server to add my own blocks to but how then does P&ID find this drawing?
I hope someone can see what Im getting at and help me out.
Thanks very much
Active Member
hans
Message 2 of 3 (372 Views)
Re: Where are blocks referenced from?
10-29-2012 01:56 AM in reply to: Tee.Dee
Also new blocks must be a part from the projSymbolStyle.dwg, from the active project. When you select a new block from an other drawing, the block will be copied to the projSymbolStyle.dwg and will be a part of your active project
Hans Knol
CADTEAM
hans@cadteam.nl
www.cadteam.nl
Tee.Dee
Message 3 of 3 (358 Views)
10-29-2012 03:42 PM in reply to: Tee.Dee
Thanks Hans,  I think im getting there, im coming from AutoCAD Elec where things work much differently.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
