AutoCAD P&ID General
Active Contributor
Jan-TSpD
Message 11 of 14 (230 Views)
Re: Valve is replaced when assigning tag
12-05-2013 12:06 AM in reply to: Jan-TSpD
i think i found a solution to the problem. I have changed the value "Gate valve" to a value used in the project (this case "Algemen afsluiter") in the file "PIP_Metric_PnIdPart.xml"
Attached a screenshot of it.
Regards, Jan
Active Contributor
Jan-TSpD
Message 12 of 14 (222 Views)
12-05-2013 07:02 AM in reply to: Jan-TSpD
Hello, i have found the solution to this problem.
The value "Gate valve" in the PIP_Metric_PnIdPart.xml has to be replaced with a value from the used project.
regards, Jan
craig.wood
Message 13 of 14 (116 Views)
02-10-2014 05:09 PM in reply to: Jan-TSpD
Jan - Great finding! I've been looking for a solution for this for nearly 2 years!
Autodesk - Please replace "Gate Valve Style" with "General Valve Style" around line 139 in both "PIP_Metric_PnIdPart.xml" (Metric) and "PnIdPart.xml" (Imperial) as the new default setting in order to fix this issue.
Thanks!
Craig
Active Contributor
Jan-TSpD
Message 14 of 14 (107 Views)
02-11-2014 12:14 AM in reply to: craig.wood
Hello Craig,
Had some sleepless nights also.
Please accept as solution or kudos.
Met vriendelijke groet,
Jan Harink, TSpD BV
Steenkampsweg 12a
7665 RA Albergen
Tel. 06 5492 7850
K.v.K. te Enschede, Nr. 08159019
BTW nr.: NL 8201.70.628.B.01
P Think before you print
________________________________
The information contained in this message and its attachments is intended only for the use of the addressee and confidential and/or legally privileged. Any unauthorized review, use, disclosure or distribution is prohibited. TSpD BV is not liable for any viruses contained in this e-mail message and/or in the attachment(s). TSpD BV cannot be held responsible or liable in any way whatsoever for and/or in connection with any consequences and/or damage resulting from the improper, incomplete and untimely dispatch and receipt of the content of this e-mail. If you received the message in error, please advise the sender immediately and destroy or delete the message.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
