AutoCAD P&ID General
Distinguished Contributor
gschimmi
Message 1 of 6 (464 Views)
Update a field for all valves, lines or measuring points
464 Views, 5 Replies
04-09-2013 04:36 AM
Hello
I have for example three parallel identical lines and need for each line one PID. The difference between them is the customized field 'areaKey' for valves, lines and measuring points. I draw the first PID. Then I copy this PID two times. Now I want to update the 'areaKey' like this
update all valves with areakey=4111 with areakey=4121
and so on
Is there a built in function or which is a good way to solve this. A little lisp would be ok too.
Thanks Guido
Plant3D 2014 German
WIN7
Rave.Tam
Message 2 of 6 (425 Views)
Re: Update a field for all valves, lines or measuring points
04-10-2013 05:52 AM in reply to: gschimmi
Data manager? Or you should probably acquire the area property from the drawing. That way, it will always stay updated with the area value of the drawing you copied to.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
gschimmi
Message 3 of 6 (420 Views)
04-10-2013 06:17 AM in reply to: Rave.Tam
but that is not what I'm looking for.
Data Manager has no 'find and replace'
We have different areakeys in one drawing
G
Plant3D 2014 German
WIN7
Rave.Tam
Message 4 of 6 (417 Views)
04-10-2013 06:28 AM in reply to: gschimmi
But there are "Filter" and "Replace" in Data Manager.
If AreaKey is common property, doesn't it shows up in the Properties palette?
gschimmi
Message 5 of 6 (390 Views)
04-11-2013 11:34 PM in reply to: Rave.Tam
Hi
Filter ok, but where is replace? I find only INSERT. But it's OK with data manager and INSERT.
(AreaKey is in the Properties palette)
Plant3D 2014 German
WIN7
Rave.Tam
Message 6 of 6 (357 Views)
04-15-2013 07:16 AM in reply to: gschimmi
Filter and Paste is actually a longer version of replace..
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
