AutoCAD P&ID General
Member
Engineerist
Message 1 of 11 (1,634 Views)
This tool is not supported in a non PNID drawing file
1634 Views, 10 Replies
10-03-2011 02:07 AM
Today i installed AutoCAD P&ID 2012, everythings is normal. But when i click on an equipment on the tool palettes. This warning is occuring. (This tool is not supported in a non PNID drawing file) Is there any one knows how to solve this problem ?? Thanks in advance..
Employee
sankarg
Message 2 of 11 (1,627 Views)
Re: This tool is not supported in a non PNID drawing file
10-03-2011 10:42 AM in reply to: Engineerist
The tools on the P&ID specific tool palettes will work only on the pnid drawing file types. You can create a pnid drawing files from the project manager by selecting the "P&ID Drawings" tree node under the project root node, and then right click select the "New Drawing" option.
Sankar Ganesh
Sr. Principal Engineer
Autodesk Plant Solutions
Autodesk, Inc
New Member
ennergy
Message 3 of 11 (1,614 Views)
10-04-2011 03:26 AM in reply to: Engineerist
I installed AutoCAD 2011 p & id, but I've tried everything but they did not have the same problem. Please help. thanks.
Product Support
jason.drew
Message 4 of 11 (1,553 Views)
10-10-2011 10:39 AM in reply to: ennergy
AutoCAD P&ID will allow you to open a standard AutoCAD drawing. So if you open a drawing manually (even one created as an AutoCAD P&ID DWG) using the File -> Open command from the menu bar or application menu, it will attempt to open the drawing outside of the project and you'll see the warning message about the drawing not belonging to the project or "This tool is not supported in a non PNID drawing file"
To avoid this message use the "Copy Drawing to Project" command from within Project Manager to bring a drawing in and make it part of the current project.
Once the drawing is part of the project remember to open your P&ID drawings from the list in Project Manager to make sure you're opening the drawing as a part of the project.
Thank you,
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Member
Engineerist
Message 5 of 11 (1,521 Views)
10-14-2011 11:52 PM in reply to: jason.drew
I am using project Manager wizard to create a project. At the end of the project everything seems OK. ( databases etc..) Then when i try to draw something from the tool palette. Autocad P&ID warning me to save this drawing, so i save the project in dwg format. ( There is no another format to save in drop menu by format type)  After that this warning always appears "This tool is not supported in a non PNID drawing file" This programme so complicated. Today i will try the CADWorx P&ID Professinonal. :smileysad:
Employee
sankarg
Message 6 of 11 (1,509 Views)
10-15-2011 09:54 AM in reply to: Engineerist
Whenever a new pnid  drawing gets added, the application adds some hint in the dwg file to indicate that it is a pnid drawing file. May be that logic is not working for some unknown reason.
Couple of options we can try:
1. In the "New DWG"  dialog, specify a different dwt template file and see if that helps
2. Please post a sample pnid drawing file of the project and we can examine the hint in the dwg to see if that is set correctly.
Sankar Ganesh
Autodesk, Inc
Member
Engineerist
Message 7 of 11 (1,492 Views)
10-16-2011 11:43 AM in reply to: sankarg
Thanks a lot Mr. Sankar Ganesh
I tried to explain what i did in the attached video below..
http://hotfile.com/dl/132495856/c08e8e3/deneme.rar.html
Thanks in advance.
Best Regards..
Employee
sankarg
Message 8 of 11 (1,469 Views)
10-17-2011 12:24 AM in reply to: Engineerist
Your workflow is correct. Both sline and P&ID tools in TP  will work only for the pnid type dwg file.
In your case, slines are working as expected in the pnid dwg file, but for some reason, executing the tool from TP fails and reporting incorrectly that the dwg is not a pnid type file.
Both slines and tools from TP do the same check to find out if the file is a pnid type dwg file.
I am not sure how this check passes correctly for slines, and fails for tools in TP.
I am sorry I couldn’t help much here.  :-(
Sankar Ganesh
Autodesk, Inc
New Member
ennergy
Message 9 of 11 (1,459 Views)
10-17-2011 03:10 AM in reply to: sankarg
mr sankar
to our workflows. p & id drawing you send the sample to try it.
thanks.
Erdemlix
Message 10 of 11 (1,387 Views)
10-26-2011 02:16 AM in reply to: ennergy
It is solved.
There was a problem previous versions. Ribbon menu was not loaded. Solution was altering the "regional and language settings " to the US. With SP1, it was solved.
It turns out setting regional language "Turkish" causes this problem too. With the chance of this set, problem solved as he said.
Addition: It is also a bug, i believe SP will cure this too.
You are not logged in.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
