AutoCAD P&ID General
adelgado
Message 1 of 7 (344 Views)
TAG ANNOTATION CONTENT LOOSES WHEN SAVING ONLY ON SCREEN
344 Views, 6 Replies
02-15-2012 03:41 AM
Hello I am using Plant3D P&ID 2011,
I have a problem with Tag Annotation in different situations.
The first is that Tag anotation value disapears on screen, but when I go to edit the tag it automaticly appears. But then I save the drawing and sometimes I open drawing again and the problem appears again.
The second problem with Tags is that sometiemes I cannot define a value in a Line number, Plant P&ID do not anything, and trying it until the trird or fourth time, it gets the number i enter and then it works.
The third problem is that sometimes tags of different inline elements change its Line number independently of Line number where they are when I open drawing after saving it.
Anyone knows what could be the problem?
Thank you to all
______________________________
TERMISA ENERGIA S.A.
http:\\www.termisa.es
Product Support
Message 2 of 7 (318 Views)
Re: TAG ANNOTATION CONTENT LOOSES WHEN SAVING ONLY ON SCREEN
02-22-2012 05:35 AM in reply to: adelgado
The first things to try is to delete the local data cache by running the PnPLocalDataCachePurger.exe. This utility is located in the install directory of the product.
Once you have done that you should audit the project.
Dan
Dan Scales
adelgado
Message 3 of 7 (309 Views)
02-23-2012 01:05 AM in reply to: adelgado
Hello Dan,
After using the PnPLocalDataCachePurger.exe, Plant3D freezes on welcome screen and it doesn't works.
How can I solve it?
Thank you
Product Support
Message 4 of 7 (305 Views)
02-23-2012 01:44 AM in reply to: adelgado
I would not normally expect this to happen after running the utility.
Have you tried re-booting the machine? I have seen this from time to time on my machine and re-booting tends to fix it.
If that doesn't help let me know and I will provide some more suggestions.
Dan
Dan Scales
adelgado
Message 5 of 7 (302 Views)
02-23-2012 02:24 AM in reply to: adelgado
I have test the same procedure on anther computer with Plant and did not happen the Freezing error.
But now the problem of freezing welcome screen on the previous computer is the main problem.
Aslo I test in that computer with another windows user account and it works and the welcome screen doesn't freeze, but the normal user continues freezing.
Please give me a solution so now we are stopped.
Thank  you very much!
Product Support
Message 6 of 7 (297 Views)
02-23-2012 03:59 AM in reply to: adelgado
I have sent you an email through the support system explaining how to trigger the secondary installer.
Dan
Dan Scales
adelgado
Message 7 of 7 (275 Views)
02-26-2012 11:48 PM in reply to: Dan.Scales
Hi Dan,
I just solved user welcome screen freezing problem.
Meanwhile TAG anotation continous with problem but it is a random problem. I think huge problem is that it changes also the check valves direction automaticly when I reopen the drawing file.
I am working in a Local project.
Thank you
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
